Weer een nieuwe kodi box, maar ik wacht wel even af hoor. http://www.futeko.com/products/MP063.php
Dit zou een openelec toestel zijn die ook in native kodi 3d kan
Ik zou absoluut afwachten !
DIRECT BOOT KODI Venztech V3 runs latest OpenELEC 6 (Linux Kodi 15.2) and boots quickly+direct into Kodi 15.2.
QUAD-CORE CPU AND QUAD-CORE GPU Quad-core Amlogic S805 CPU providing easily enough power for Kodi and powerful quad-core Mali-450 GPU capable of high bitrate 1080p video playback including BD-ISO.
SIMPLE OPERATION Unlike Android or Windows alternatives, the V3 boots direct into Kodi and requires no installation or setup. It is perfect for users who just want fast and easy Kodi.
COMPREHENSIVE ADD-ON COMPATIBILITY Venztech V3 offers great compatibility with Kodi add-ons. Note that no add-ons are pre-installed, see FAQ below.
24/50/60HZ AUTO SWITCHING Output can be set to automatically switch between 24/50/60Hz depending on content frame rate.
5.1 CHANNEL HD-AUDIO 5.1 channel DTS and Dolby Digital HD-Audio formats can be decoded and bitstreamed.
24BIT 192KHZ AUDIO Venztech V3 supports 24bit up to 192kHz audio via HDMI. This makes it a very viable as a high-end audio device.
HIGH QUALITY HARDWARE Venztech have a strong history in Android / Kodi boxes, having OEM manufactured TLBB amongst others. They are well respected for producing high quality hardware with top quality components.
FULLY FUNCTIONED REMOTE Supplied IR remote is fully functioned and ideal for controlling Kodi. You can optionally add practically any USB wireless RF mouse/keyboard/airmouse.
WI-FI WITH EXTERNAL ANTENNA PLUS ETHERNET Wi-fi (2.4Ghz a/b/g/n) with large and effective antenna for great wi-fi reception. 10/100 LAN for reliable wired networking.
EXTENSIVE EXPANSION CAPABILITY External ports: 3x USB 2.0 host, 1x micro-SD, S/PDIF TOSLINK, HDMI 1.4b video/audio.
BOX CONTENTS Venztech V3, IR remote, HDMI cable, UK PSU (plus adapter if ordered from 2-pin Europlug country).
