As you can see, each model is pretty rich in sense of design with distinct characteristics that designed by ZIDOO.Deeply optimized system, hardware-decoding capabilities and continuous update services. Right now,we also inject these characteristics into the new model. It's based on Rockchip 3368, not only high-performance, but also unique.
64-bit
ZIDOO X6 Pro Powered by Cortex-A53 Rockchip 3368 Octa-core CPU, into 64-bit era,Because of 64-bit CPU,address space can be up to 64GB processing speed and width are double too.64-bit can dramatically affect the OS application and the whole industrial structure.
2G+16G
2G DDR3 make big games run more smoothly The utilization of eMMC memory offers an array of benefits in terms of performance security and reliability, a richer end-user experience
WIFI
ZIDOO X6 Pro use Broadcom AP6335 dual-band WIFI,It supports IEEE 802.11a/b/g/n/mimo, 802.11ac,2.4GHz/5GHz. It can achieve up to a speed of 433.3Mbps withe single stream in 802.11ac draft to connect to the wireless LAN
1000M network interface carry 1000M network interface 4K image, carefreely shows in front of audience with 10 times speed through current mainstream 100M ,without any pressure limit
BT 4.0
ZIDOO X6 Pro is embedded with Bt 4.0 module It can reduce 3 miliseconds delay the transfer-distance can be more than 10 meter,and support AES-128 coding. It is compatible with 2.0,2.1 and 3.0 all BT standards
HDMI 2.0 4K*60p
ZIDOO X6 Pro supports hdmi output with the resolution 4K*2K@60fps ZIDOO choose the high-end HDMI cable as standard accessories to match X6 You can enjoy large-scale games which require UHD frame rate@60fps can enjoy 18Gbps data transfer and 12-Bit real-color without any data losing on ZIDOO X6
PMU Built-in ZIDOO unique PMU power management chip, ZIDOO X6 Pro can achieve completely switch IR Contral and dormancy function It is the first Android TV BOX support auto power off and standby
Android 5.1
Pre-installed Android 5.1 Lollipop,after ZIDOO depth optimization, ZIDOO X6 Pro can offer smoother multi-tasking for users to switch among applications easily and offer more security
Unified storage ZIDOO X6 Pro original firmware uses unified storage, more available space than other device,you can install more applications
Support 4k*2k H.265 Hardware Decoding
ZIDOO X6 Pro offers 4K*2K UHD video playback, support 4K@60fps, support HD Audio(7.1CH) passthrough、24P frame rate auto switch Pre-installed ZIDOO customized KODI 15.0 Isengard support Hardware decoding
BD-ISO and 3D BD-ISO
Support BD iso,BDMV,BD rip,BD 3D MVC format playback on video player and kodi.
ZIUI By ZIUI, you can use the most simple operation to manage applications, files, set the parental lock, speed system, everything goes with the flow Certainly, it is pretty nice
ZIDOO MEDIA CENTER X6 Pro has been built-in the programpaket of ZIDOO MEDIA CENTER, which costs ZIDOO a whole year to develop
It’s been never so simple to operate album, manage files, play music, access to LAN. During using a number of features, you would know how powerful it is
Airplay,airmirror,DLNA,miracast,zidoo rc,google remote all in one!!
ZIDOO RC Through ZIDOO RC, you can use your favorite operating way to control X6 Pro with your cell phone
IR Shortcut and learning
The new smart IR remote with progrmmable keys offers a great easy way to control not only the X6 Pro Octa-core but also the TV at your home It also supports three programmable color-keys that customizes to open apps quickly
Support HDMI CEC Control
Cloudfront CDN------Ota
We use the global Cloudfront CDN services, you can easily and stably to get OTA upgrade in any corner of the world. You will see, our active and iterative firmware. All of these are free
As always support software update, in response to users community, regularly update firmware
