Kodi 14.0 “Helix” alpha 2 Kodi 14, which we gave the codename “
Helix“, is shaping up to be what is often called a “stability” release. In software development, many projects operate on a sort of tick-tock release schedule. The “tick” often introduces new features, dramatically alters the UI, and can likely dramatically alter the underlying framework of the software. The “tock” on the other hand, goes back and cleans up the code, fixing old incompatibilities, eliminating UI inconsistencies, and often preparing the groundwork for the next major tick. Where Gotham was quite definitely a “tick,” Helix is shaping up to be a “tock.”
With that said, several features, fixes, and updates have been included so far that are definitely worth discussing. The Next Generation of Video Codecs
To begin, Kodi has been updated to use FFmpeg 2.2.4. For users, this means Kodi will now be capable of playing back h.265 (also known as HEVC) and VP9 video codecs. This could result in dramatically smaller video files sizes with exactly the same level of quality. A 40 GB file could be compressed to 20 GB. A 1 GB file could be compressed to 500 MB without any loss in perceivable quality. Users with particularly large libraries or interest in 4K video may be especially likely to appreciate this update. The caveat to this update is that it is entirely software based. This means most low power systems, such as those operating Android or iOS, may struggle compared to the heftier HTPCs or Intel NUCs and ZOTAC ZBOXes that are running desktop and laptop processors. Library Improvements The Kodi Library is getting improvements both coming in and going out. On the input side, library scanning is receiving a massive speed boost, which should make the initial scan on Android and iOS devices quite a bit more spritely. On the output side, work continues, slowly but surely, on UPnP. Kodi is now significantly more compatible with servers like PlayOn and MediaBrowser, as client-related bugs have been dealt with. Further, communication between Kodi UPnP clients and Kodi UPnP servers continues to improve with proper or additional support for categories like date added, ratings, votes, and artwork, along with sorting for those new categories. UPnP search functions are also slowly working their way into Kodi. Android and iOS On the Android side, hardware playback improvements continue, including more and better support for various chipsets, improved fast forward and rewind capability, as well as 4K support for the AMLogic s802 chipset. On the iOS side, Airplay, which was fairly substantially broken by the update to iOS 7, appears to be almost entirely fixed on every platform save Android, which lacks certain software support, making Airplay playback only partially fixed on that platform. Windows, OSX, and Linux All three platforms continue to see improvements in audio playback and a reduction of many audio-related bugs that have been plaguing the platforms for a long time. Other Changes The changelog for Kodi 14 is 12 pages long and contains 333 changes so far. Needless to say, they can’t all be summarized here, but a few additional items worth noting include:
- * Update PVR add-ons
- * Start of redesigning the PVR windows
- * Various improvements to the Audio Engine, with the OSX platform as great beneficiary.
- * Improvements to the GUI skinning engine
- * Extended JSON-RPC interface
- * Countless smaller and larger bug-fixes throughout the program and vast improvements in every area. This should improve memory usage, stability, speed and user friendliness.
- * Add-ons are still compatible up to the Frodo versions.
- * Skins are partially still compatible, however to fully function they will need to be updated to latest changes. Expect breakage here.
Add-ons As for this Helix release, so far there have only been small things changed in regards to add-ons. So we are happy to say that almost all add-ons that worked in Gotham, will also work in Helix. There are of course some exceptions, however this should be only be a minimal amount. Skins Creating a skins for Kodi takes many months of designing, coding, testing, tweaking and a lot of patience to get it just right. However with every major Kodi (past XBMC) release there is the problem of skins becoming incompatible due to various code changes. So for every release people who put a lot of effort creating these skins, need to adapt it for the next Kodi version. This could mean that your favourite skin doesn’t work in the next Kodi version. We are very glad to say, that thanks to a group of skin developers, there are already 2 Helix compatible skins available in our repository. From memory this has never happened before, that within the alpha stage there are already skins available for you to enjoy using. On our forum there are several more skins being worked on, to get these into shape for people to use. So hopefully by the time of final release, there will be several more available. So let’s all thank the developers for their hard work they do for the community. Helix compatible skins in our repository at the moment are: Aeon Nox 5, Transparency!
Other are still included however they may lack the functionality you have been used to in some areas.
