En met een andere mediaspeler is het wel goed?
geeez, kalf!mysteryliner zei:oops. Dacht dat ik dit er in had staan. Het gaat over de series via kodi.
With the rise of all the new 4K content, playback devices and displays, having proper 4K playback on Android is becoming a more and more nice thing to have. Although true 4K implementation for applications like Kodi is only planned in Android M, one of our developer found a way to at least incorporate this for the Android 5.0 platform. With the help of the people from NVIDIA and their newly released SHIELD Android TV we can now say Kodi will do it’s user interface and video playback in full 4k@60Hz should your device support this. IMPORTANT: The improvements mentioned will require that you at least use Android 5.0 and your devices must have the proper implementation of these features to support it. It could mean that you have to wait for future firmware updates for your device. Adaptive seeking The Step Forward, Step Back and Small Step Back actions are now forwarded to a new seeking function that is configurable in the GUI via the Skip steps and Skip delay settings. It allows single skip steps backwards and forwards with the left and right cursor keys as before, however a new feature is that by pressing the left and right keys multiple times you can skip with increasingly larger steps. Another feature of this new seeking function is that music files can also now can make use of skip steps. You can watch this short YouTube video for a quick explanation:
Although this release post is all about the upcoming 15.0 version, mentioning the DX11 upgrade for next version is very important. Since day and age Kodi (and XBMC in the past) has used the DirectX 9 implementation for various task of rendering the user interface and media playback. This almost dated back to the XBOX days. With the hardware industry moving and focussing more on the newer DX11 with their drivers, more people have problems with running our outdated DX 9 version. This could range from simply not starting, crashing just after loading, playing videos or having problems with hardware acceleration. One of our developers afedchin took on this task and completely revised our DirectX 9 implementation and upgraded it to the more current standard of DirectX 11. Don’t worry if you still have an older card, we only use low level features so you don’t need to run to the shop for new gear. If you are having problems on Windows you can head to our forum where you can find the most recent build available which is currently based on our 15.0 release. We appreciate all the feedback we can get. Read more: here. Again this will not be part of our final 15.0 release, it will be in 16.0
You are also welcome to continue sideloading it from the Kodi downloads page. In terms of Kodi for Android specific features, 4K, refreshrate switching, and HEVC playback are now available on devices with hardware that support those features including a number of Amlogic based devices and the NVIDIA Shield Android TV, though it should be noted that Android 5.0 and above is required to take advantage of these features. Kodi 15.0 Features Across platforms, Kodi itself has gained quite a lot of features. Some notable examples include: • A new chapter selector window – Allows you to visually browse and select chapters from mkvs and other containers that support chapters. <woltlab-metacode data-name="media" data-attributes="">https://www.youtube.com/watch?v=5wn4KIJcHNI</woltlab-metacode>
• Language Add-ons and Expanded International Preferences – Now language translations aren’t dependent upon release, but get regularly updated to all users as the add-ons themselves update. Additionally, you now have total control over date, time, temperature and more displayed formats.
Improved Add-on Manager – The add-on manager has now been reworked to help make finding the add-ons you are looking for easier.
Additional Improvements and Changes Other improvements include:
Although this release post is all about the 15.0 version, mentioning the DX11 upgrade for Kodi 16 is very important. One of our developers afedchin took on this task and completely revised our DirectX 9 implementation and upgraded it to the more current standard of DirectX 11. Don’t worry if you still have an older card, we only use low level features so you don’t need to run to the shop for new gear. If you are having problems on Windows you can head to our forum where you can find the most recent build available which is currently based on our 15.0 release. We appreciate all the feedback we can get. Read more: here. Again this will not be part of our final 15.0 release, it will be in 16.0. hetzelfde als bij films. De folder met muziek toevoegen, maar bij de volgende stap (scraper) kies je i.p.v. film muziek.Xenomorph zei:Domme vraag na al die jaren al XBMC gebruikt te hebben maar hoe scan je je muziek eigenlijk? Bij update wordt alleen gekeken naar tv en film maar muziek wordt niet geupdate! Nu staat muziek gewoon in lijst modus. Weet iemand ook hoe lyrics en die foto's tijdens het afspelen uitgeschakeld wordt, heb er een hekel aan en vind het niet om het uit te schakelen.
De lyrics add-on uitschakelen en de artist foto add-on (ofzoiets) uitschakelen. Kan je meestal ook regelen via de settings van je skin.Xenomorph zei:Domme vraag na al die jaren al XBMC gebruikt te hebben maar hoe scan je je muziek eigenlijk? Bij update wordt alleen gekeken naar tv en film maar muziek wordt niet geupdate! Nu staat muziek gewoon in lijst modus. Weet iemand ook hoe lyrics en die foto's tijdens het afspelen uitgeschakeld wordt, heb er een hekel aan en vind het niet om het uit te schakelen.
scraper is er toch alleen voor muziek videos??mysteryliner zei:hetzelfde als bij films.De folder met muziek toevoegen, maar bij de volgende stap (scraper) kies je i.p.v. film muziek.
Na het Zoeken heb je onder muziek een nieuwe categorie.
Lyrics en foto's. .. Ofwel bij de add-on die daar voor zorgt. Ofwel tijdens het spelen van je muziek eens bij extra's. (Zoals je subtitels kiest bij een film... daar in de buurt)
