De local install, update.sh script nagekeken en dan dat gebruikt.
installed, en nog werkt het niet
homeassistant:
  customize_glob:
    sensor.unifi_*:
      templates:
        hs_color: "if (state === 'up') return [115,100];
          else return [360,100];"
    sensor.unraid_server:
      templates:
Philip,Nog iets vreemd.
Op de pagina van mn server, lukt alles van glances, echter zodra ik die attributen toevoeg, verdwijnt alles van de pagina, ik vind de fout niet, kun je ff zien in mn code aub?
title: Server
icon: mdi:nas
path: server
theme: ios-dark-mode
cards:
  - type: vertical-stack
    cards:
      - type: custom:vertical-stack-in-card
        title: Unraid Server
        cards:
          - type: horizontal-stack
            cards:
              - type: custom:card-modder
                card:
                  type: picture
                  image: /local/unraid.png
              - type: custom:entity-attributes-card
                title: Kenmerken
                filter:
                  include:
                    - key: sensor.server_motherboard
                    - key: sensor.server_cpu
                    - key: sensor.server_memory
                    - key: sensor.server_diskspace
                    - key: sensor.server_arraystatus
                    - key: sensor.server_arrayprotection
          - type: conditional
            conditions:
              - entity: sensor.glances_disk_used_percent
                state_not: "unavailable"
                state_not: "unknown"
            card:
                type: custom:bar-card
                align: split
                show_icon: true
                padding: 4px
                columns: 2
                card_style:
                  border-radius: 5px
                severity:
                - value: 50
                  color: '#3bb3ee'
                - value: 80
                  color: '#e7a24a'
                - value: 100
                  color: '#ff0000'
                entities:
                    title: Disk
                    max: 100
                  - entity: sensor.glances_cpu_used
                    title: CPU
                    max: 100
          - type: conditional
            conditions:
            card:
                align: split
                show_icon: true
                padding: 4px
                columns: 2
                card_style:
                  border-radius: 5px
                severity:
                - value: 50
                  color: '#3bb3ee'
                - value: 80
                  color: '#e7a24a'
                - value: 100
                  color: '#ff0000'
                entities:
                  - entity: sensor.glances_swap_used_percent
                    title: SWAP
                    max: 100
                  - entity: sensor.glances_ram_used_percent
                    title: RAM
                    max: 100
          - type: conditional
            conditions:
              - entity: sensor.glances_containers_active
                state_not: '0'
            card:
                align: split
                show_icon: true
                padding: 4px
                columns: 2
                card_style:
                  border-radius: 5px
                entities:
                  - entity: sensor.glances_containers_ram_used
                    title: Docker RAM
                    max: 10000
                  - entity: sensor.glances_containers_cpu_used
                    title: Docker CPU
                    max: 100
          - type: conditional
            conditions:
            card:
                align: left
                title_position: left
                show_icon: true
                padding: 4px
                columns: 1
                card_style:
                  border-radius: 5px
                severity:
                - value: 50
                  color: '#3bb3ee'
                - value: 80
                  color: '#e7a24a'
                - value: 100
                  color: '#ff0000'
                entities:
                    title: Containers
                    max: 40
Zie https://github.com/ElectricBrainUK/UnraidAPI/wiki/Lovelace-Config
Philip,
Jij gebruikt ook die custom header he
Ik wil daarin namelijk het volgende krijgen
- een greeting afhankelijk van tijd
- notificaties
dmv vertical scroller
ik heb momenteel al een greeting maar niet in die header
cards:
  - type: markdown
    content: >
      {% set time = states('sensor.time') %}
      {% if '00:00' < time < '06:00' %} ## Goeie Nacht !
      {% elif '06:00' < time < '12:00' %} ## Goeie Morgen !
      {% elif '12:00' < time < '18:00' %} ## Goeie Middag !
      {% else %} ## Goeie Avond !
      {% endif %}
Enig idee hoe ik dit werkend krijg, het lukt me niet
Kan ik voor die notificatie gewoon een conditional card gebruiken? Veel meer dan if state is x, dan tekst... moet het niet zijn
Ik kan mn eigen post niet bewerken, dus dan deze
Ik heb het gevonden, zalig !!
Mocht iemand interesse hebben
sensor:
  - platform: time_date
    display_options:
      - time
      - date
      - date_time
  - platform: template
    sensors:
      greeting:
        value_template: >
          {% set state = states('sensor.time') %}
          {% if '00:00' <= state  < '06:00' %}
            Goeienacht !
          {% elif '06:00' <= state  < '12:00' %}
            Goeiemorgen !
          {% elif '12:00' <= state  < '18:00' %}
            Goeiemiddag !
          {% else %}
            Goeieavond !
          {% endif %}
Ik wil nog eentje met de temperatuur, krijg een syntax error
{% set temperature = state_attr('weather.home', 'temperature'), color="var(--google-blue-500)", symbol="°C") %}
Error rendering template: TemplateSyntaxError: expected token 'end of statement block', got '='
Momenteel doe ik aan presence detection via wifi
MAAR
snachts is dat een probleem, gezien de wifi van de tel dan uitvalt en ik zogezegd weg ben.
Maar ook als ik thuis kom, zou het iets sneller moeten detecteren
De vraag is, wat is een beter alternatief?
Via google maps?
Via bluetooth ? (i dunno of het bereik van de pi dan wel voldoende is en of die ook uitschakelt snachts?)
Via home assistant app? (maar dan moet ik of nr de cloud gaan (betalen) of zelf open zetten, maar das dan poorten openzetten wat ik eigenlijk niet wil
Via life360?
Maar dan deel je wel je locatie... extern
Nog een vraag
Iemand die o365 integratie werkend heeft?
https://github.com/PTST/O365-HomeAssistant
Ik heb alles goed ingesteld maar loop dus tegen de volgende error aan:
The reply URL specified in the request does not match the reply URLs configured for the application
Probleem is dat ik geen http mag invullen als die url, het moet een https zijn, dat heb ik dus niet
Het volgende lees ik ook : Please ensure that you have configured base_url in your http config https://www.home-assistant.io/integrations/http/#base_url and that you have added the correct reply url to your Azure app
Die base-url gaat mn petje te boven
Kan iemand me hiermee op een makkelijke manier bij helpen, of gaat dat niet?
