Kodi topic
Mq5 uit
http://forum.xbmc.org/showthread.php?tid=174501
Let op de special thanks to
De eerste update voor versie 3.2 van het Open Embedded Linux Entertainment Center is uitgekomen. Deze Linux-distributie is gebaseerd op standaarddownload zijn er speciale versies voor AMD's Fusion- en Nvidia's ION-platform, Apple TV, Xtreamer Ultra en Raspberry Pi. De changelog voor deze versie laat de volgende veranderingen en verbeteringen zien:
<woltlab-quote data-author="" data-link=""> Changelog
  • update to xf86-video-intel-2.99.903
  • update to xbmc-12.2-cd71444
  • update to linux-3.10.13
  • update to service.openelec.settings-0.2.16
  • update to bcm2835-bootloader-86e7643
  • update to bcm2835-driver-86e7643
  • update to llvm-3.3
  • update to libva-driver-intel-1.2.1
  • update to libaacs-0.6.0, convert to new package format
  • update to libbluray-0.3.0, convert to new package format
  • update to wlan-firmware-0.0.14
  • update to fuse-exfat-1.0.1
  • update to timezone-data-2013d
  • update RPi kernel patch
  • downgrade to xf86-video-fglrx-12.10
  • downgrade to curl-7.31.0, this should solve non working FTP sources in XBMC
  • linux: fix setting up ondemand up_threshold value
  • linux: add support for Ubiquiti WifiStation
  • linux: mac80211: ignore (E)CSA in probe response frames, this should fix #2617
  • busybox: prevent cdrom from autoclose, this should fix #2510
  • Fixed eventlircd's 03_0755_2626.evmap to make most of the buttons of iRF Media Technology W-01RN_USB_V3.1 IR remote work out of the box.
  • bluez: fix udev rule for logitech keyboard support, this should fix #2599
  • eventlircd: add support for MS-Tech remotes
  • kmod: add patch to support /storage/.config/modprobe.d
  • v4l-utils: added some keys to rc6_mce map for xbox360 slim black remote, fixes #2331
  • eventlircd: update holtek remote mappings
  • linux: fix tevi s471
  • eventlircd: set default first repeat to 1000ms to avoid double keypresses on some remotes
  • xbmc: After suspend wait for the first NIC to come up before continuing
  • projects/*/linux: remove PSTATE support again
  • bcm2835-bootloader: fix create sdcard script
  • udevil: add 'nonempty' option for exfat
  • udevil: support mounting disks without partition tables
</woltlab-quote>
is er een manier om het audio menu van XBMC te programmeren op je Harmony one? Heb die code niet gevonden!
Je kan alles programmeren van xbmc he, is maar wat je wil uit dat audio menu
Heb nog niet gevonden hoe daar in moet geraken met je remote! Doe dat nog steeds met de muis als de film begint want soms speelt hij de verkeerde audio stream (bvb DD ipv DTS bij QoQ)
Ik heb mijn harmony one eens aangepast om die audio (dd ipv dts) te kunnen instellen... Maar ik gebruik die niet meer... maar het ging wel.. dus het is 100% mogelijk Voor zover ik me kan herinneren moet je de keymappen instellen..     Dus met je harmony one, kan je keypresses simuleren... En die keys kan je in xbmc ook configureren   Dus alles is mogelijk   Je harmony one, stel je in in het progje van harmony En de keys in xbmc, kijk hier eens:   http://wiki.xbmc.org/index.php?title=Keyboards     Veel succes, duurt wel even voordat je het doorhebt, maar 1x instellen en het is klaar he
    Ik gebruik absoluut geen muis ! Maar de mele f10
Nog een vraagje:   Heb gezien in Ace en nu weer in MQ5 dat mijn info icoontjes (dtshd, mkv,etc...) corrupt zijn en niet allemaal goed doorkomen op het scherm! Aan wat ligt dat? Precies of ze niet uitgelijnd zijn zoals bvb nfo bestandjes die je dload!
Tuurlijk !
Er is zelfs een screenshot map he   print screen?
[sub] Kijk eens vanonder naar de info tags: [/sub]   [sub]
[/sub]
Nog nooit gezien, ik heb dit niet.. Bij Ace ook zeg je? Ik zoek het even op
  misschien een driver issue? resolutie instelling ... XBMC staat op 1920x1080
Lijkt me sterk, zou je het dan niet op meer plaatsen moeten zien dan alleen bij die info icoontjes ?
Nee denk niet dat dit een driver issue is Heb je het op bv een desktop ook?
Geen idee, bestaan er geen media flag (want dat zijn het) packs voor XBMC en gebruik je er daar geen eentje van ?
Bloody, wordt moeilijk. Je geluk reeds geprobeerd op het XBMC forum ?
