Dear users, Aeon MQ 5 - Final 1.5.1 - available in oficial repo.
Only Frodo version by now. The Gotham version will be analyzed and will be sent to a separate repository for XBMC Gotham soon.
Changelog:
Added: GlassList view - Tagline for TvShows.
Added: Options for show/hide widgets for Settings Menu and Favourites Menu.
Added: Widgets Modes - Always visible, manual (old clean mode) and auto.
Added: Multiple backgrounds in Main Menu - Slide transition timer.
Added: Disc Art - swing speed control.
Added: Disc Style Selector.
Added: Media Flags - Automatic hide mode.
Added: WMC PVR - Support to series recording (thanks to TheImmortal)
Added: Wall view - Information Panel.
Added: 3DWall view - Support to episodes.
Added: Option to hide tagline for movies and tvshows.
Added: Main Menu Customization/Weather - preview icons, static or animated.
Added: Music OSD - Info button.
Added: Main Menu - Transparency level for all panels.
Added: Media Case - Individual on/off for each view type.
Added: Disc Art - Individual on/off for each view type.
Added: Option to disable first widget "In Progress".
Added: First Settings, in steps - To prevent errors in first settings on some systems.
Added: Music Views - All views available for non-library mode.
Improved: Font size for all information panels.
Improved: Main Menu - Trailer in window mode.
Improved: Panel view - Dimmer style.
Improved: ShowArt view - Layout details.
Changed: Widgets effect, slide to fade - to prevent skin freeze in some cases.
Fixed: GlassList view - Missing item name during the playing,
Fixed: RCB - Multiplex view - Aspect ratio for thumbs.
Fixed: Video Extras script - Compatible to latest build.
Fixed: Media Flags Bar/Transparency selector - Layout details.
Fixed: Double items in the information panel to Albums and artists.
I will give a brief description of the main changes:
- When using multiple background images in the main menu you can set the transition time between 5s, 10s, 30s, 1min, 30min or 1hour.
- Now we have a disc selector. It is possible to set the rotation speed of the disc and also the style, are five different options.
- For those who like the library in Clean mode, media flags won the automatic mode.
- The Wall view gets a new meaning. While browsing through the items but nothing changes just stand still for a few seconds and will have an information panel on the item. The rest of the items becomes transparent where you can see the fanart. There is still time settings panel and also a transparency selector.
- The Main Menu now more charming, the transparency level acts on all panels.
- Media Cases can now be turned on and off individually for each view, the same goes for disc art.
- When there is an update that has the self-reconfiguration skin will show a progress screen adjustments. The intention is to divide the first set in blocks in order to reduce the peak load. Thus the chance of some writing fails is less.
- For those who prefer to listen to your music without library mode, now all views are available.
- All sources of information in the panels were enlarged for easier reading.
- The main menu widget now has 3 modes of operation; always visible(default), manual(old clean mode) and the automatic.
And a bunch of little things.
Have fun.
I thank all who have helped build this skin.
